December 7, 2004, 03:05 |
How to calculate and plot y+ & T.I. ?
Hi all
I am using STAR-CD 3.22. Base case using high Re number k-e model and standard wall function has been converged. At this moment, I hope to check my mesh generation is adequate. Can you let me know how to calculate y+ and turbulence intensity and plot them? Thanks in advance. Jihwan |
December 7, 2004, 05:57 |
Re: How to calculate and plot y+ & T.I. ?
To plot y+ at wall you can use standart ProSTAR facilities. First of all, you have to write y+ to .pst file (a check button in Analysis Output). After you load .pst file just select Data to load - Wall Data, and there will be Y+. Don't use averaging! Then look for ProSTAR output, which type of cell was created for wall boundaries. Select cells of this type and go to main menu: Plot->Wall Plot. Plot type shoul be Contour plot.
Relationship between turbulent intensity and k and epsilon is somewhere in Methodology |
How can I calculate it? | cfd novice | Siemens | 0 | April 3, 2008 18:36 |
how to calculate y+ in cfx? | micaheal | CFX | 3 | November 21, 2005 14:45 |
How can we calculate? | Salman | FLUENT | 1 | August 26, 2005 08:54 |
calculate cp | Pete | Siemens | 1 | March 2, 2005 20:58 |
how to calculate y+ | kat | Main CFD Forum | 1 | February 11, 2004 09:46 |
