Droplet track coded file
Old   January 11, 2005, 04:20
Default Droplet track coded file
Habib
Hi I did export the ascii of the droplet track file of transient spray and I looked at the file and the order of the column seem to be as follows N, x, y , x, u , v , w , etc. anyway , The first colums seems to represtnet the parcel no. In the middle of the file I found some parcels have negative parcel no. how ?? and its number is the same as the previous one in magnitude but with negative sign while the value of velocity, diameter and all others are exactly the same. I do not know why ?. that is my question? I appreciate your suggestion.
Old   January 11, 2005, 08:00
Default Re: Droplet track coded file
Richard
The negative index is used to mark the end of the track.
Old   January 11, 2005, 21:04
Habib
Thank you for your reply, I am trying to figure out how the rows of the file are organized but I could not understand. I know whatthe columns of file are. The first column which suppose to be the parcel no is not systematically organizd.
I have 64 parcel each time step. so I am expecting that 64 rows from 1....64 and then the next row should start again from 1 to 128....and so on.
what I see in my file is that some parcels disappeared and then appeared again in the later times. and also that negative values of the parcel no. Which I do not think it represents the of the track because then this parcel should not appear again.
no problems at all when viewing the spray in prostar and the track file in starSD menue looks fine.
Anyone know how can I export the droplet track file as I see it in star CD menue
Thank you
Why? Preferred droplet track in Two-Phase flows Maurice Kettner Siemens 4 January 3, 2012 11:25
particle/droplet track data Jay Siemens 1 April 17, 2008 01:28
Why is droplet track file overwritten ? mic Siemens 6 July 12, 2007 10:46
To store droplet data into a readable file selen Siemens 9 August 22, 2003 11:12
Why? Preferred droplet track in Two-Phase flows Maurice Kettner Main CFD Forum 2 February 1, 2000 14:08
