January 17, 2005, 13:11 |
recirculations at inlet/outlet cavity
My question is about unsettled/unrealistic recirculations at the inlet and outlet cavities. I am modeling a cavity between rotor and stator. In the entire cavity, there are some flow obstructions attached to stator like labyrinth teeth. I defined high/low static pressure at inlet and outlet boundaries. Rotor surface is rotating at an rpm. I like to calculate mass flow rate as function of pressure drop. I used k-epsilon approach. I turned on "density ideal-f(T,P)" for compressible flow. I tried many options to have a nice streamlined flow at inlet/outlet cavities. It looks like rotor speed in the tangential direction causing the recirculation problem. I defined a linear tangential velocity which is maximum over rotor and zero at stator. I tried zero gradients on pressure boundaries. I extended/shortened the inlet/outlet cavities to get a developed flow conditions. However none of the tries have worked so far. Any ideas to resolve the problem would be appreciated. Thank you in advance for any help. Abe. |
Display Modes | |
Could anybody help me about the specify inlet and outlet | liugx212 | OpenFOAM Running, Solving & CFD | 4 | February 13, 2006 10:53 |
how to set inlet and outlet? | green | Phoenics | 5 | May 18, 2004 23:52 |
one inlet and two outlet | Fluenter | FLUENT | 2 | March 28, 2004 23:23 |
use outlet as inlet | Karin | Phoenics | 3 | March 31, 2003 22:12 |
Outlet -> Inlet How? | lego | CFX | 2 | August 13, 2002 12:23 |
