convection terms on/off
Old   January 26, 2005, 06:08
Default convection terms on/off
cm
Hi
Do you know if it is possible to run a model that has scalars along with all their flow variables and scalars with these u,v,w & P turned off at the same time?
I have not been able to do it.
Appreciate any suggestions
Many thanks
CM
Old   January 26, 2005, 13:56
Default Re: convection terms on/off
Brian
I'm not exactly sure what you're asking, but it sounds like a method I use for dye tracing and flow visualiztion.
First get a converged steady state solution. Now create a scalar, and run the model for one iteration to initialize the scalar all at zero.
Then set up a transient case, using the existing solution as an initial field, and switch off the solution of everything except the scalar. Put in at least one non-zero boundary condition for the scalar.
It runs really fast and you get to see the dye move through the domain.
Different Terms in Different UDS Carlos V. FLUENT 2 April 4, 2006 07:19
Discretization scheme for Convection Terms Mohammad Kazemi CFX 16 December 7, 2004 22:38
separating conduction and convection terms Jeff FLUENT 0 November 26, 2003 02:32
convection dominated convection-diffusion problem Kang, S. K. Main CFD Forum 0 December 22, 2000 14:25
Convection Terms in UDF Jon Thorpe FLUENT 1 August 14, 2000 09:41
