February 23, 2005, 05:56 |
changing boundaries
I want to simulate a model with let say five inlets and one outlet,but all inlets should not work at a same time that means inlets are time dependent. Suppose i want to trigger first 2 inlets rest inlets should be treated as wall and then as one time step is over next inlets should be triggered. STAR-Cd user guide says we can do that by advanced transients option and GT-power but how to use that and how to redefine the boundary type e.g changing from wall to inlet and vice versa i dont know. If anybody help me out of this i wld be grateful.
February 23, 2005, 09:53 |
Re: changing boundaries
Can you leave it as an inlet and set the velocities to zero? In other words, when an inlet isn't flowing, you live without wall type functionality - say heat transfer or wall functions.
If so, you can define a time dependent velocity with a table or user subroutine (I believe it's bcdefi.f). |
February 24, 2005, 05:06 |
The correct way to do this is using load steps - see "Analysis Controls for Transient Problems" - "Load-step based solution mode" in the User Guide.
February 25, 2005, 02:38 |
in user guide they are not specifying any info about changing boundary type with change of time. any other help is available anywhere?
February 26, 2005, 06:33 |
The boundary conditions, together with boundary types, are saved for each load step. So create a load step, set up the boundaries for that load step, then save the load step. Repeat for each load step - you can change boundary type as well as values.
Also note the use of ramp or step changes in load steps. |
Display Modes | |
UDF for changing viscosity | Rafael | FLUENT | 2 | October 28, 2009 16:59 |
Changing RPM | Amir Hossein Birjandi | FLUENT | 2 | March 4, 2008 01:51 |
changing co-ordinates | Mac | Siemens | 1 | December 27, 2007 09:38 |
changing of k-e model | Sima Baheri | Phoenics | 0 | May 18, 2006 05:52 |
Changing BC | Riham | FLUENT | 5 | January 15, 2004 21:54 |
