coarse grid to fine grid crashing
Old   February 22, 2005, 11:58
Default coarse grid to fine grid crashing
Arnab
Hello
I have a quick question,
First, we ran transient successfully with a coarse grid. After using the coarse grid solution to restart the fine grid case using the same time step and the default solution parameters, the code crashed with negative densities. Is this a symptom of having too big a time step or relaxation parameters? Can anyone recommend some values?
Old   February 22, 2005, 13:27
Default Re: coarse grid to fine grid crashing
Richard
The Courant number is inversely proportional to the cell size, so if you have the same velocity and time-step, Co will increase. The higher Co, the more likely instability. If you refine the mesh, it's good practice to reduce the time-step accordingly.
HOW turbulene Grid (avoid too fine or too coarse)? Toulouser FLUENT 1 February 1, 2007 04:47
Nonlinear Multigrid: Coarse Grid Operators Greg Lewin Main CFD Forum 0 December 1, 2006 10:39
CFdesign behaviour in coarse and fine mesh Farhad Autodesk Simulation CFD 0 May 30, 2006 11:10
How to coarse my grid Luca Main CFD Forum 0 March 15, 2006 03:56
Fine grid embedding Philip Peeples Phoenics 1 July 3, 2002 19:32
