How to solve the problem for table and Les?
Old   March 1, 2005, 02:23
Default How to solve the problem for table and Les?
Ben Lu
My model is the pipe form.There are two inlets and vertical each other,and one outlet.Time Domain is transient and turbulence model set is LES/smagorinsky.The curve of two inlet velocities are developed flow,and the values are used by tables in option of Define Boundary Region.Differencing scheme select "CD".After i start apply the "start new analysis",Startcd shows the error" error occurs in readying table.Form the proble file.its data is ingnored".And When th turbulence model is K-E/High reynolds and velocity used by table,Starcd didn't shows above error and could run to result.How to slove the error please? thanks
Incoherent problem table in hollow-fiber spinning Gianni FLUENT 0 April 5, 2008 10:33
Table script problem Scibor Siemens 0 April 30, 2007 05:10
How to solve this problem liugx212 OpenFOAM Running, Solving & CFD 4 March 21, 2006 10:19
Boundary table problem. Thanks for help leon Siemens 0 September 7, 2005 16:20
Help me to solve this problem !!! kevin -Chang FLUENT 3 November 24, 2002 00:43
