combustion_modeling
Old   December 29, 2004, 10:43
Default combustion_modeling
Jane Gilbert
I am simulating the combustion process of GDI engine.The spray is initiated through the inbult spray panel.Here I am using local sources combustion modeling with premixed mixture.The rate model is CHKI with standard options. The ignition cell is also located.The question is : I am not getting the mixture ignited and hence the case runs as if it were a cold case analysis. Is there some other parameters like activation energy ignition temperature? Is there any other combustion model inbuilt in starCD which can be suitably adopted?
Thanks for responding
Jane Gilbert
Old   February 1, 2005, 23:41
Default Re: combustion_modeling
user500
Use "transport" instead of "Internal" for the scalars.
Old   March 1, 2005, 07:36
AKMEAA
Can you send me the combustion model to my email address.
