*** WARNING #060 *** DENSITY OUT OF BOUND DUE T |
March 25, 2005, 16:19 |
*** WARNING #060 *** DENSITY OUT OF BOUND DUE TO PRESSURE CORRECTION AT CELL 1295 DENSITY= 1.2757E-03 LIMITER APPLIED.
i am working on the intake and compression strokes of an i.c.engine. I am getting this warnings in the .info file and the solution stops saying that the solution is unstable,solution diverges.This iam getting at the very first time step.when the valve starts opening. i am working on the intake and compression strokes of an i.c.engine. what can be done to avoid this warning and to run the simulation.plz help |
Create an upper bound | daniel_mills | OpenFOAM Running, Solving & CFD | 0 | October 20, 2006 18:34 |
Density out of bound | Prashant Khare | Siemens | 3 | August 1, 2004 22:35 |
Bound node loop. | Jack Keays | FLUENT | 5 | July 9, 2000 13:57 |
Low Re k-e model bound. conds | Abhijit Tilak | Main CFD Forum | 1 | October 7, 1999 05:31 |
Compressible N-S bound. condn. | Kuttoosan | Main CFD Forum | 1 | July 6, 1999 12:46 |
