March 29, 2005, 04:02 |
Plotting Problem/Error
I am running a transient analysis with free surface option. When I am plotting the current results (the current analysis time is at 0.3 secs), I get only the results on a very small area of the whole mesh. For instance, if I want to plot UVW velocities (or pressure), the 'colorful arrows (or contours)' appear only in some (less than 5%) area of the whole mesh and I know from logic that this is not the case. What may be the problem? Is it sth to do with my model, or there other stuff that I need to do to get the correct plot. Please advice and thanks... Shazlan |
March 29, 2005, 05:05 |
Re: Plotting Problem/Error
"When I am plotting ..."
This is not helpfull. If you instead write down the commands you used, it is much easier to find out what went wrong. |
March 29, 2005, 05:09 |
ok... here you go. is this sufficient? or if there's a way i can upload the screendump, please let me know. apprecaite your help! thanks..
trload,toinew.pstt,nomvgr,,c store,iter,67 psys,1 getc, ALL ,None plty ehid, $edge,off $plme,off $lswi,off$ popt,vect $thin,1 $term,,,vect $cplo plty sect, $surf,on $edge off$ plme,off $lswi,off$ popt,vect $thin,1 $term,,,vect $repl shazlan |
March 30, 2005, 05:19 |
if you do an "edge on" you will see, how the section is defined within the domain. Maybe it only cuts a small area of the domain.
Plotting problem in paraFOAM | velan | OpenFOAM Running, Solving & CFD | 2 | December 8, 2008 04:55 |
plotting file error | julie | FLUENT | 1 | December 19, 2005 10:32 |
Urgent plotting problem in Post...Please help. | Alan | CFX | 1 | March 28, 2005 18:46 |
problem in plotting cl curve | kiran | FLUENT | 5 | August 11, 2004 11:04 |
y+ - plotting problem -cfx5.4.1 | joseph | CFX | 2 | September 7, 2001 10:06 |
