April 8, 2005, 05:19 |
trimmed mesh
Hi All,
I am doing trimmed mesh in pro*am. In that I want partitions in volume, means I want to distinguish some regions with distinct partition though connected. Those are rotationg and atationary domains. So I can couple them creating independantly. Kindly guide how to create partitions in trimmed mesh. Thanks. |
April 11, 2005, 21:37 |
Re: trimmed mesh
Hello
Use shells to seperate the regions, it might mean that you have to do two seperarte trimms for each volume and then cpar them using shells or what we call Cp Match planes. Here is a nice button to bring two domains together, cpta 100 arbi cset news type 10 !Shell of one Volume cset add type 20 !Shell of the 2nd volume vset news cset cset news vset face cset subs fluid cshell 10 cset cshell 20 cset cpar shell 10 20 !10 Must be the smaller one |
April 12, 2005, 04:34 |
Re: trimmed mesh
You are not allowed to have couples at the interface between fluid/solid, fluid/porous and steady/rotating at MRF calulations. So it is probably not the best idea to go this way.
April 12, 2005, 20:31 |
Re: trimmed mesh
well, extrude the layers in between
April 12, 2005, 20:43 |
Re: trimmed mesh
Thank You Alex, I left that part out, when you trim with thoose planes make sure you allow a subsurface. You can do one of 2 things, have the core mesh spin 2 and the extrusion layer spin 1 which you couple to the other domain, but then face 7 8 of a trim cell might be attached to the extrusion layer, the cure is to "cmre cset" but the trick is to get those cells in your cset by doing a geom write to an ofile and making a list you can ifile, but the other option is to do a cmro 1d on the extrusion layer of that plane, then you will have a 1 to 1 connection between spin and no spin.
April 18, 2005, 03:32 |
another question about grid
dear all
now I encounter a problem about layer, I have never dealtwith such a problem, detailed like following: In generate mesh->mesh tools->cell quality checks the result show that face area exist6errors, volume exist 8 errors and Tet Quality exist 9 errors.Now I can not completely understand these, I beg to be helped, thanks! |
trimmed mesh | Tester | Main CFD Forum | 0 | January 6, 2008 11:32 |
Ngeom Crashing on Trimmed / Hexahedral Mesh | Fr Ted Crilly | Siemens | 2 | October 13, 2005 07:08 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
Trimmed mesh in Proam | Sam | Siemens | 1 | May 29, 2005 20:16 |
Trimmed Surface (CFX5.5) | Nelson | CFX | 11 | October 18, 2002 16:16 |
