heat transfer coefficient - forced convection
Old   March 26, 2005, 08:23
Default heat transfer coefficient - forced convection
Tes
Dear Gurus, please help me to solve the following problem:
TARGET: to map the convective heat transfer coefficient (H.T.C., h_cell, [W/m2 K]), without using the energy equation (the "cold" approximation I mean) using a cell by cell formulation, along the frontier of a 3D very complex geometry (many characteristic lengths, confined domain, forced convection)
Velocity and pressure field are known everywhere (already computed with a RANS FVM code). Lots of velocity gradients are present inside the whole domain. The flow is incompressible with M << 0.3 and isothermal, Pr = 0.7.
Someone told me to use the flat plate approximation computing for each wall cell the local Nusselt relation like this:
Nu(x) = c * (Re(x)^n )* Pr^m
where c, n and m are the laminar/turbulent coefficient suggested by Schlichting ("B.L. Theory" pag. 298-299)
Re(x) = density * vel_cell * x / viscosity
and substituting in:
h(x) = k * Nu(x) / x
to obtain the H.T.C., h(x).
The main problem is:
> what is "x" for my 3D CFD problem cell by cell based?
> Is a correct approximation to choose the wall cell mean length as "x" supposing that this dimension is inside the boundary layer (x=Lmean_cell)?
> What is the best choose for vel_cell?
Any contribution would be really appreciated.
Tes
Old   March 27, 2005, 03:21
Default Re: heat transfer coefficient - forced convection
dpshaka
it is relative to your flow direction
since you want to addopte a flate plate approximation, you should use the main streamdirction
Old   April 16, 2005, 18:14
yves van roy
I am making tests on a solar collector and for my theoretical determination of the absorbed energie I have to know the heat transfer coefficient at the outside of the collector to know how much energie I lose due to convection. Could somebody give me an aproximation for this coefficient when there is a little wind and when there is a lot of wind?
Forced convection heat transfer in heat sink Sidy FLUENT 1 October 18, 2008 03:27
Heat sink-forced convection Marc FLUENT 0 May 7, 2007 03:51
heat convection in a forced fluid Daniele COMSOL 0 December 20, 2005 08:09
heat transfer coefficient - forced convection Tes FLUENT 0 March 26, 2005 08:32
heat transfer coefficient - forced convection Tes Main CFD Forum 0 March 26, 2005 08:17
