humidity
Old   May 9, 2005, 02:35
Default humidity
sankar
How to incorporate effect of humity in airflow processs, ie psychrometric process.
sankar
Old   May 9, 2005, 12:35
Default Re: humidity
Ted Crilly
i dont think this can be done with Star-CD, i would also be interested to find out if this is possible in star-cd
Old   May 10, 2005, 04:06
Anton Lyaskin
What about defining water vapor as an active scalar, affecting the properties of the fluid?
Old   May 11, 2005, 01:31
sankar
If u define water vapour as ascalar, in case of an evaporator water will condense by taking latent heat from air how to simulate this? we have to remove mass and heat from the system via user coding for sources is is correct?
sankar
Old   May 12, 2005, 06:24
Anton Lyaskin
I think yes, though I've never faced such a complicated problem myself. You can try to ask support, may be they already have samples of such user subroutines.
humidity Son FLUENT 0 October 7, 2008 05:06
Humidity Nuno Leal FLUENT 0 October 17, 2006 03:37
humidity Milad FLUENT 0 April 15, 2006 06:11
Humidity rr FLUENT 0 February 14, 2003 09:20
Air with humidity Dan Sorensen Siemens 0 February 10, 2000 08:53
