VOF and Droplet Formation
Old   May 13, 2005, 15:22
Default VOF and Droplet Formation
saang
Now, I am solving "Droplet formation" problem by using free surface model in Prostar. But,the formation shape is still not right, while it jets out. What should I do?
Is anybody here trying to solve "Drolet Formation (a single droplet coming out of nozzle)" in Prostar? Please tell me some experience or let's discuss.
Old   June 7, 2005, 03:59
Default Re: VOF and Droplet Formation
4xF
Concerning your problem, you should be aware that all simulations codes tend to have the same problem with surface tension modeling when using the Continuum Surface Force method (which is the case for STAR-CD) and when the surface tension forces are higher or in the same order of magnitude as the convective forces. The numerical discretisation creates so-called parasitic currents (See also the review article of Scardovelli & Zaleski, 1999) which may influence the flow pattern. These velocities are not physical and may lead to a false solution. This may be eventually the case in your simulation.
Hope this helps you further...
Ice Particle formation using CFX Dinesh CFX 1 April 7, 2010 17:39
Help with droplet formation in T-junction. Kes FLUENT 0 May 16, 2008 01:48
Drop formation fly CFX 0 June 20, 2006 00:50
droplet formation Dominik Main CFD Forum 1 July 13, 2005 12:56
SOx formation olivier Main CFD Forum 0 December 18, 2001 12:27
