Recommended values on turbulence B.C.
Old   August 9, 2005, 00:48
Default Recommended values on turbulence B.C.
Jihwan
Hi there,
I am not good at turbulence. But, as you know, it is very important to consider turbulence for the flow in complicated geometries. What I want to know is that whether there are good recommendations for the turbulence boundary conditions. Of course, the turbulence B.C. should depend on flow pass and environments. I hope to get any literature concerning recommended turbulence boundary conditions for various flow conditions and geometry. Thanks in advance and good luck everybody
Jihwan
Old   August 10, 2005, 03:53
Default Re: Recommended values on turbulence B.C.
AlexMuthaiah
Hi, Turbulence Boundary condition in the sense u need to maintain a suitable Y+ values around the wall region and which inturn depend on ur tubulence models which u r going to use. For each TModels appropriate closure coefficients u need to use usually software will take care by using its default values.
U need to check for gridsenstivity.
regards'
Alex
Old   August 10, 2005, 07:45
allan
Hi
If you are considering inlet boundaries then you could try setting turbulence intensity to say 2%, running the model then double it and run the model again and so on until there isn't any appreciable difference in the turbulent flow field.
For internal flows length scale can be set to 10% of the hydraulic diameter of the duct.
Y+ is also very important, but if you choose hybrid wall functions then it becomes less of an issue.
allan
turbulence values nando FLUENT 0 December 12, 2005 03:45
values for turbulence models Ben Siemens 8 July 12, 2004 13:42
Help - Wind Turbulence Values Erich Main CFD Forum 0 November 11, 2003 18:32
Turbulence boundary values lego CFX 9 October 25, 2002 11:55
Turbulence boundary values lego Main CFD Forum 0 October 24, 2002 13:47
