Surface Evapaoration
Old   August 26, 2005, 08:22
Default Surface Evapaoration
Dhandapani.s
Hi All, CFD Simulation in Star- CD â€"Problem Definition. 1.Refrigerant (Freon 134) is flowing thro the evaporator coil in liquid state at Inlet. 2.Air is flowing from top to bottom cross flow to the refrigerant medium. 3.Refrigerant will take heat from air and phase change will occur from liquid to vapour in side the evaporator coil (Multiphase). I would to simulate phase change of refrigerent inside the evaporator from liquid to vapour state in Star-CD.Please, let me know the approach to simulate my above problem.
Thanks Dhandapani.
Old   August 27, 2005, 10:21
Default Re: Surface Evapaoration
tomosada
Hi! Dhandapani
You can use the Beta function of VOF in STAR-CD.
I think you can refer the UserGuide for more information.
tomosada
Old   November 4, 2005, 10:34
İbrahim Utku Başyazıcı
Hi I would like to solve in tube refrigerant condensation but I couldnt describe phase change in my model like you. Could you find a solution for phase change? if you can How can I solve my problem. Could you please help me?
thanks
Old   November 10, 2005, 10:37
tomosada
You can user the beta function of VOF .
contact your local STAR-CD distribute.
Recover surface from surface mesh in IcemCFD Jerry Tanner CFX 0 August 20, 2008 12:48
surface to surface radiation heat transfer? suresh Siemens 1 July 7, 2006 06:54
surface tension gradient on a free surface Abrem FLUENT 1 April 30, 2006 03:41
Surface tension - Continuum Surface Force model Robert Main CFD Forum 0 May 2, 2002 07:34
[surface tension effect at free-surface ?] name Main CFD Forum 1 September 21, 2001 09:54
