August 12, 2005, 06:14 |
moving grid
I am interested in usage of an application through star-CD. Can any body suggest where exactly related tutorial is available. If not, I request software support engineers to provide pdf file electronically.
Thanks! Dr C.Bhasker |
August 12, 2005, 08:39 |
Re: moving grid
related to what?
August 12, 2005, 11:38 |
Re: moving grid
Automobile piston-cylinder circuit breaker SF6 gas normally comes the standard tutorial with software but not available.
Thanks Dr C.Bhasker |
August 17, 2005, 04:11 |
Re: moving grid
You can refer tut 13 of STAR-CD (prostar) regarding moving mesh with piston cylinder arrangement.
All the Best Rajesh |
August 31, 2005, 02:29 |
Re: moving grid
Good luck with tut13. That will take some time for understanding for a beginner.
Another possibility is ProICE bei adapco as a mesh generator for comb. engines. ProICE helps you to define the event modeller in a´much esier way. If possible use this, but it is much expensive. |
moving grid | mazaheri | FLUENT | 1 | July 19, 2006 12:07 |
Grid Moving | Karthik Krishna | FLUENT | 4 | February 23, 2005 07:57 |
HELP: moving grid | Sunlight007 | Siemens | 0 | June 5, 2003 17:11 |
moving grid | Vikas Kumar | Main CFD Forum | 1 | May 5, 2003 05:14 |
Moving grid(BC) | faithkim | Main CFD Forum | 11 | September 11, 1999 14:07 |
