Star design not working in LINUX AS 3.0 For ITANIU
Old   October 27, 2005, 04:38
Default Star design not working in LINUX AS 3.0 For ITANIU
Shajin P.C.
We are using Red hat Linux 2.1AS On ITANIUM 2 M/Cs. Later we upgraded our OS to Linux 3.0AS, we found that All modules except Star Design are working.Plz help in this regard.
Old   October 28, 2005, 05:44
Default Re: Star design not working in LINUX AS 3.0 For IT
Malc
You may need to install compatibility libraries on your OS. There is no 64 bit Parasolid kernel available for Linux Itanium (which is what STAR-Design uses for its solid modelling capability), so on Linux Itanium the 32 bit version is supplied. This means that the OS has to be able to run 32 bit applications, which is probably an option that needs to be selected on setup. You might be able to install the compatibility libraries separately.
how to export a mesh from star design to star cd aounallah Siemens 4 March 6, 2009 06:22
FLUENT AIX export to LINUX keyboard not working ZaPiTo FLUENT 0 December 7, 2006 18:43
Star watch not working rajesh Siemens 2 May 19, 2006 02:51
Star-CCM+ Set Working Directory Bart Siemens 1 September 1, 2005 01:01
Linux: when the job suddenly stops working. Stevie Wonder CFX 3 August 15, 2004 18:36
