Converegence problem
Old   September 16, 2005, 05:39
Default Converegence problem
Ahmad Al-Zoubi
Hallo All,
I have problem to get convergence in thr presence of momentum source term. Any Hints are willcome.
Ahmad Al-Zoubi
Old   September 16, 2005, 07:16
Default Re: Converegence problem
4xF
1) Underrelax more
2) If the source term depends on the variable itself and the coefficient is negative, then put the coefficient into the implicit part of the source term (e.g. into S2U, S2V or S2W depending on the variable)
Old   September 16, 2005, 10:06
Ahmad Al-Zoubi
Thanks alot,
I have tried this. It seems that it convereges BUT very very slowly... I think it is a simple problem which don't require such huge number of iterations.
by the way, my source term is a constant velocity (-2m/s).
Any other hints?.
Ahmad Al-Zoubi
Old   September 28, 2005, 10:59
4xF
Have you also checked the units of the source term? It should be in N/m^3
VOF diffuse problem on two fluids problem Fang Jin FLUENT 5 February 17, 2011 05:38
Problem in Modelling Heat Transfer Problem Deepak R FLUENT 1 December 6, 2007 09:37
Problem in cavity flow problem saad Main CFD Forum 4 November 1, 2007 07:45
Problem in Tutorial problem of fluent Phanindra FLUENT 5 April 17, 2007 09:57
problem in solving "wave generation" problem san FLUENT 2 April 3, 2006 23:37
