leaving black areas
Old   October 13, 2005, 11:42
Default leaving black areas
flow
hi,
i have some basic problems (using star on unix) and need help:
after i used a toolbox which requires a selection from the main window, this toolbox partly hide my screen. after i chose the option the toolbox disappears but leaving a black area. i could't replot until the selection is done.
can i activate a continuous replot function or anything like that?
greetings.
Old   October 14, 2005, 03:20
Default Re: leaving black areas
Andreas
hello,
you should enable backing store in your X-Server. The installation guide gives hints how to do it on your unix system. After enabling backing store the black area problem should be gone
Bye Andreas
Old   October 14, 2005, 05:52
flow
thanks a lot. it works now.
Old   November 17, 2005, 05:00
Tushar
Go to /etc/X11/Xconfig file and in Screen section add the following line
Option "BackingStore" "On"
Black hardcopy CCM+ Gump01 Siemens 6 September 25, 2008 11:06
Fluent People leaving 4merfluent FLUENT 7 June 20, 2008 09:50
Red-Black SOR vs. SOR rt Main CFD Forum 0 April 25, 2007 06:45
Some help for Red black SOR with OpenMP Davoche Main CFD Forum 1 February 5, 2006 17:19
Interrupting Gambit w/o leaving CPU busy? Chris Bailey FLUENT 0 January 26, 2005 16:29
