The problem of wall data getting when postprocessi
Old   December 20, 2005, 20:49
Default The problem of wall data getting when postprocessi
WIlliams
When using the command "getw,ftot,p,rela" in windows 2000 version STAR-CD to load wall data,the output window gave erro message "**NOTE - REALLOCATING MEMORY CREATING WALL BOUNDARY SHELLS **ERROR - NOT ENOUGH SCRATCH SPACE. USE THE MEMORY COMMAND TO SET PARAMETER MAXSC2 TO AT LEAST 18577799, THEN REISSUE HIS COMMAND"!
I used "memory maxsc2 ????(a number)" and "memory write" and run "getw,ftot,p,rela" again and the Prostar interface shutdown!
After Prostar interface shutdown: error message is:
segmentation fault
The solved problem have 0.7 million cells such number is small for my computer,Can any one tell meb what is the matter?
appreciates your help!
thank you!
Williams
Old   December 21, 2005, 03:22
Default Re: The problem of wall data getting when postproc
allan
TRY
MEMO MAXSC2 18577799
then reissue the command
probably better to change the value of maxsc2 in prosize.
allan
Old   December 22, 2005, 01:22
WIlliams
Thank you for your suggestion!
I have tried it,but the prostar shutdown still and the cmd console gave the segmentation fault erro.
I am at the end of my wits!
Isn't it a bug of STAR-CD for windows version?
I have no idea!
Thank you anyway, Allan!
Old   December 22, 2005, 03:18
allan
To determine wether it is a bug or not try starting prostar without the graphical interface, under linux it is the x option. If the command works i.e. returns you to the prompt then it's a bug.
Then contact your local support.
Hope this helps
allan
Old   March 6, 2006, 10:14
Konstantinos
I have exaclty the same problem in Windows XP proffesional and its really annoying, I dont know what to do! Did you ever manage to solve the problem?
Wall temperature data in helical pipe! Wael Siemens 3 November 1, 2014 10:42
Unsteady Wall Shear Stress Data Repoting Arash FLUENT 1 February 13, 2008 14:36
wall data Pete Siemens 2 August 25, 2005 04:06
read in wall data Ethan Siemens 0 March 29, 2003 15:19
HELP: Wall variable temp is not on the data file? Jiaying X Siemens 4 September 19, 2002 13:30
