Error #84
Old   February 8, 2006, 04:39
Default Error #84
Maki
Hi
I have a problem with coupling. the error #84 said : A master cell face in one couple is defined as a slave cell face in another couple.
How can I fix the problem? if you know how to do, would you tell me what I should do?
Best regards
Maki
Old   February 11, 2006, 18:07
Default Re: Error #84
DB
delete all the coupling and try to make coupling again
Old   February 13, 2006, 02:48
Maki
thanks I did that once. but I will try again
Old   February 13, 2006, 02:58
Anton Lyaskin
Try assigning different cell types to master and slave cells and specifying cell type during coupling
Old   February 14, 2006, 20:11
Default THANK YOU
Maki
Thank you for the advice. finally I could fix the problem!
strange fluent error: Primitive Error at Node 0 Jean-Baptiste FLUENT 8 June 14, 2022 11:11
error in COMSOL:'ERROR:6164 Duplicate Variable' bhushas COMSOL 1 May 30, 2008 04:35
"Error: Floating point error: invalid number" MI Kim FLUENT 2 January 4, 2007 10:00
Fatal error error writing to tmp No space left on device maka OpenFOAM Installation 2 April 3, 2006 08:48
Error: Floating point error: invalid number Bob FLUENT 3 June 3, 2005 18:11
