subroutine reacfn.f
I am thinking of using star-subroutine reacfn.f
sample code included Hybrid-reaction model is as follow ************************************************** ****** SUBROUTINE REACFN(RATE) ~~~~~~~~~~~~ abbrev. ~~~~~~~~~~~ CC WMF and WMR are fuel and reactant molecular weights ZERO=0.0 WMF=16.0 WMR=32.0 UGC=8314.3 IF(IR.EQ.1) THEN CC Eddy break-up rate dependent on minimum of fuel, reactant and CC Product mass fractions RMFR=MAX(ZERO,AMFU) RRFR=MAX(ZERO,AMRC(1)/4.0) RMFR=MIN(RMFR,RRFR) RPFR=MAX(ZERO,BEBM*AMFB) RMFR=MIN(RMFR,RPFR) CC Eddy break-up reaction rate RSOUE=DEN*TAUL*AEBM*RMFR CC Chemical kinetic rate RCON=ARCK*WMF* * T**BETCK*EXP(-EACT/(UGC*T)) RCON=RCON*(DEN*MAX(ZERO,AMFU)/ * WMF)**RTCKF RCON=RCON*(DEN*MAX(ZERO,AMRC(1))/ * WMR)**RTCKR(1) CC Minimum rate RATE=MIN(RSOUE,RCON) ENDIF ************************************************** ****** 2-step reaction model 1st C3H8 + 3.5O2 -> 3CO + 4H2O ==>rate1 2nd CO + 0.5O2 -> CO2 ==>rate2 if i want to use 2 step model, how do I use those? because the problem is that return value is only one "RATE"! in addition, I compared with result using subroutine sample codes and using STAR-CD setting value about 1 step reaction model but I found out different contours of Temperature what is the problem? thank you for my words |
Re: subroutine reacfn.f
Parameter IR indicates which reaction RATE corresponds to. So this subrotine is called for each reaction, each cell. You only need to do sth. like if (ir. eq. 1) ... rate=rate1 elseif (ir .eq. 2) ... rate=rate2 endif
You need to make sure you set up everything exactly same to each other for the two cases. THe sample subroutine apparently is a combined-rate EBU model. In pro-star, you can set is as EBU, combined-time, combtined-rate or finite-rate chemistry. |
Dear. Zhang
I have one more question I have make codes for propane and air would you tell me why there is the different results between coding and PROSTAR setting(combined rate model) my coding have something wrong ? the sample code is as follow 1-STEP(combined model) ************************************************** * ZERO=0.0 WMF=44.1 WMR=32.0 UGC=8314.3 s_oxid=5*WMR/(1.0*WMF) s_prod=1.0+s_oxid Aebu=4.0 Bebu=0.5 IF(IR.EQ.1) THEN CC Eddy break-up rate dependent on minimum of fuel, reactant and CC Product mass fractions RMFR=MAX(ZERO,AMFU) RRFR=MAX(ZERO,AMRC(1)/s_oxid) RMFR=MIN(RMFR,RRFR) RPFR=MAX(ZERO,Bebu*AMFB/s_prod) RMFR=MIN(RMFR,RPFR) CC Eddy break-up reaction rate RSOUE=DEN*TAUL*Aebu*RMFR cc Extinction tau_tur=0.41*(VISM/DE/DEN)**(1/2) tau_chem=DEN*AMFM/RSOUE CC Minimum rate IF(tau_tur<tau_chem) THEN RSOUE=0.0 ENDIF CC Chemical kinetic rate RCON=ARCK*WMF* * T**BETCK*EXP(-EACT/(UGC*T)) RCON=RCON*(DEN*MAX(ZERO,AMFU)/ * WMF)**RTCKF RCON=RCON*(DEN*MAX(ZERO,AMRC(1))/ * WMR)**RTCKR(1) RATE=MIN(RSOUE,RCON) ENDIF ************************************************** ****** and more,... when I make code as follow, Is the parameters in AMFB,AMFU in reaction1 part different with AMFB,AMFU in reaction2 ?? IF(IR.EQ.1) THEN ... AMFB - Fuel burnt mass fraction AMFU - Fuel mass fraction AMRC(IA) - Reactant IA mass fraction RTCKR(IA) - Reactant IA exponent RATE=MIN(RSOUE,RCON) ENDIF ... IF(IR.EQ.2) THEN ... AMFB - Fuel burnt mass fraction AMFU - Fuel mass fraction AMRC(IA) - Reactant IA mass fraction RTCKR(IA) - Reactant IA exponent RATE=MIN(RSOUE,RCON) ... ENDIF RETURN END |
For EBU setup, did you use local or global time scale? For rate expression, did you include the products? The code for extinction is not clear, so no idea about it.
The RATE is the reaction rate for leading reactant. For two reactions, the reactants can't be IA at the same time, because the leading reactants must be different for different reactions. |
I used local time scale and product is as follow
RPFR=MAX(ZERO,Bebu*AMFB/s_prod) and I'm sorry that I added extinction method. How can I use variables, such as AMFB,AMFU,AMRC(1) for 2-step reaction? Aren't there other method that I can get a scalar value How can I get the scalar values for 2nd step(CO+O2->CO2)? ******************************************* COMMON/USREAI/IR,NR COMMON/USREAR/TAUL,TAUG,AEBM,BEBM,AMFU,AMFB,ARCK,BETCK,EACT, * RTCKF,AMRC(3),RTCKR(3) DIMENSION SCALAR(50), HFORM(50) ~~~~~~~~abbrev. ~!~~~~~~~~~ EQUIVALENCE( UDAT04(006), P ) EQUIVALENCE( UDAT04(008), TE ) EQUIVALENCE( UDAT04(009), SCALAR(01) ) EQUIVALENCE( UDAT04(059), U ) EQUIVALENCE( UDAT04(060), V ) EQUIVALENCE( UDAT04(061), W ) EQUIVALENCE( UDAT04(062), VISM ) ~~~~~~~~abbrev. ~!~~~~~~~~~ ************************************ |
