May 10, 2006, 09:21 |
how to get cell face area and U in registers
Hi, everyone:
In a pipe flow, I want to get the U component of velocity and the cell face area of the layer cells, I have try to use inte command, but the result is not right. Are there any other ways to get the U multiply Area of the cells and load them in registers. |
May 11, 2006, 06:48 |
Re: how to get cell face area and U in registers
load the result data plot the cells and then type these commands in input window 1)getc u none 2)oper getc area 4 3)oper mult 1 4 5 you will get area * Uvel data in register 5.
May 15, 2006, 10:50 |
( oprer getc area 4 )can only load shell or baffle area, this comand can not load cell area, so value in register is zero.
May 16, 2006, 08:47 |
Put shells on the faces that you want areas for.
Area of a particular face of the cell using UDF | krish | Fluent UDF and Scheme Programming | 20 | September 16, 2015 05:08 |
Face Area | Corentin | FLUENT | 2 | April 9, 2008 11:33 |
how to get cell face area in RADPRO.F | cthsieh | Siemens | 1 | January 2, 2007 08:53 |
cell velocity U and its cell face area | Chinayu | Siemens | 0 | May 6, 2006 22:44 |
face area | John | FLUENT | 1 | August 13, 2002 04:12 |
