June 9, 2006, 02:34 |
HCOEF - Helical Pipe
Hi. I am modling flow and H.T. in helical pipe. I am trying to calculate the heat transfer coefficient using the adapco-online Dr. Post help (HCOEF using fluid bulk temperature). Dr. Post uses the SW velocity in calciulating the bulk temperature. It works well in my straight pipe model. However, it gives negative values in case of helical pipe. I tried the ABSO oper as the velocity (I use SU) in helical pipe +ve and -ve in the general Cartisian Cooridenates, but it did not work , HCOEF is -ve, too. Please help. Thanks. W.A.
Wall temperature data in helical pipe! | Wael | Siemens | 3 | November 1, 2014 10:42 |
hcoef problem | raffap | Siemens | 0 | May 9, 2007 05:56 |
Wall Temp - Helical pipe - Help ! | Wael | Siemens | 1 | February 28, 2006 01:40 |
Helical pipe - Wall temperature | Wael | FLUENT | 0 | January 17, 2006 20:56 |
Helical Sweep | arunachalam | FLUENT | 1 | September 13, 2002 10:36 |
