Specified angle flow rate measurement in a pipe.
Old   June 17, 2006, 21:49
Default Specified angle flow rate measurement in a pipe.
Sarala
In a 360 degree cylinder pipe I divide the cross section into 72 pieces,namely,each angle is 5 degree.In the experiment ,I measure the veloctiy profile of the straight path from 10 degree to 190 degree compared with that from 0 degree to 180 degree in a cylinder pipe. My question is how to measure the velocity profile at the specified θ angle in the pipe.(ps:not the flow rate across all the cross section but the specified θ angel.) Thank you sincerely.
Defining Massflow rate at an angle vis CFX 3 April 28, 2021 10:50
Angle measurement in CFX sham CFX 0 September 2, 2006 00:26
Flow measurement around intake valve pressure condition problem fedegavo OpenFOAM Running, Solving & CFD 1 January 20, 2006 13:06
Specific mass flow rate in a pipe-like subdomain James CFX 0 July 28, 2003 17:30
Flow field measurement in turbomachinery! Wanlai Lin Main CFD Forum 3 September 3, 1999 12:06
