September 22, 2006, 10:01 |
Launder-sharma
I would like to program (Fortran) the launder& sharma model in starcd. Can somebody help me ? which subroutines ? Sorkep and vistur ? All the best |
September 23, 2006, 10:55 |
Re: Launder-sharma
As far as I remeber, I would say you need both. You need sorkep to include the f1, f2 etc in the production terms of k and e. You need vistur to implement the damping function fu in eddy viscosity.
Hope that helps. |
September 27, 2006, 02:26 |
Re: Launder-sharma
Thank for your comments.
The main problem seems that in tne LS models, there are source terms in the k-e equations with spatial derivation of k and e which are not available in user subroutine commons best |
September 27, 2006, 20:07 |
Re: Launder-sharma
Yes, you would need to calculate those using the various routines to calculate gradients etc... You will need the necessary subroutines allowing you to calculate these. Contacting STAR CD support system should help with those. Here are some to calculate velocity gradient and scalar gradient,
CALL VELGRD(UG,GU,S,CX,SB,NFONE,KEY,URO,URSI,VISTG,DENG ,TKG, & VISCLAM,MON,ISTYP) IF(LSWTCH(60))THEN CALL GRSCGT & (FI,10,NBMAX,NCTMAX,DFI,KEY,S,CX,NFONE,SB,MON,ISTY P) ELSEIF(LSWTCH(33))THEN CALL GRADSC(FI,10,NBMAX,NCTMAX,DFI,KEY,S,CX,NFONE,MON) ELSE CALL GRSCL2(10,FI,KEY,NBMAX,NCTMAX,DFI,CX,S,NFONE,MON,I STYP) ENDIF |
October 2, 2006, 04:18 |
Re: Launder-sharma *NM*
October 2, 2006, 04:20 |
Re: Launder-sharma
Thank Sheila,
You give me some hope, about the possibility to calculate these gradient. Sure I will contact the starcd support and maybe take a user subroutine formation |
October 31, 2006, 06:30 |
Re: Launder-sharma
hello sir Iam Malika ; I want to know if you can send me some ofdocumentation about (StarCD , )also the VOF method.
Kato Launder UDF | mike laudrap | FLUENT | 1 | February 12, 2008 05:15 |
Gibson Launder | Konstantinos | Siemens | 0 | March 8, 2006 06:19 |
sanjib das sharma | Jan Rusaas | CFX | 5 | August 2, 2001 06:21 |
HELP URGENT: model turbulent LAUNDER SHARMA | dory | FLUENT | 3 | August 5, 2000 19:18 |
Launder & Sharma model in combusion case | Richard Carroni | Main CFD Forum | 1 | November 17, 1998 18:59 |
