Star CCM+ and Mandriva Linux 2007
Old   February 28, 2007, 11:57
Default Star CCM+ and Mandriva Linux 2007
Vmax
I'm going to buy a new 64bit workstaton, and I'd like to install Mandriva Linux and CCM+ V2 on it, together with 8+ gb ram. Is it possible to use Star CCM+ V2 under the Mandriva Linux 2007 operating system? And if yes, someone has some feedback? Better or worse than under Windows? Thank you. Vmax
Old   February 28, 2007, 13:05
Default Re: Star CCM+ and Mandriva Linux 2007
TG
star-ccm+ is officially supported for Suse Enterprise and Red Hat Enterprise. It may or may not work on any other version of linux, but you will not receive support for it on other versions if it doesn't work. I have used it on both linux and windows and I doesn't see much difference between them on the desktop. I haven't tried it on a 64bit windows system yet.
Old   February 28, 2007, 13:10
AR
Yes it is possible
Star-CCM+ on x64 system require jdk v 1.5.x linux-amd64
install jdk then ccm+ and enjoy
Old   February 28, 2007, 13:12
AR
I have run StarCCM+ on FC-6, Debian-Etch and OpaenSuSe systems
Old   February 28, 2007, 14:37
Linux is better than windows for CFD.
On Linux always use offical O.S. : suse and redhat and not open source weird DIY OS like mandriva, mandrake, feudor, etc...
Old   February 28, 2007, 18:01
Vmax
Thank you AR!
I think it should work straightforward also on Mandriva as all linux distros share the same fundamentals blocks. Tell me more about your experiences in Linux, how is better than Windoze, I mean, memory allocation, stability, speed, what else?
Thanks, Vmax
Parallel Processing with Linux/Unix Mandriva giogio FLUENT 1 April 3, 2008 14:19
