Problem while running solver in star4.0 for linux |
March 5, 2007, 00:52 |
I am dealing with a problem by using es-ice and prostar in starcd v4 for linux But when I run my solver,it doesnt work. Here is the infomation.
***ERROR*** STAR was not initialized properly on HOST localhost. ==> Please check that you have defined STAR correctly in your initialization files. How can i modify some parameters for HOST? what are the initialization files (software.ini and hardware.ini)??? how can I modify them? thx a lot! |
March 5, 2007, 14:03 |
Re: Problem while running solver in star4.0 for li
have a look in the install notes
March 5, 2007, 19:48 |
yes,I have had a look at it.But I am 2 new to operate linux.My prostar is ok but solver(star)doesnt work.I dont know where to modify in hardware.ini and software.ini Could you help me?Ben? Thx!!!
March 12, 2007, 23:38 |
What kind of Linux and Fortran compiler versions do you use?
Regards |
March 13, 2007, 06:32 |
I had the same problem, but I solved it. You just go to STAR folder->bin->STAR. Right click on that file and open Properties. In "Permissions" put the check mark in "Execute". Then try to run Star.
Regards |
March 13, 2007, 20:17 |
yep,I has modified its properties.The problem has gone but a new one comes out.
linyoo-deisler:~ # star star: Missing command, must specify -x -c -u -r -t -copy -n or -diff. When I start it in STARLAUNCH, I fails again. So whats the problems now??? WHY missing command? |
March 13, 2007, 21:14 |
What is your Linux version?
March 14, 2007, 04:16 |
SLED 10 SUSE LINUX ENTERPRISE DESKTOP V10 wots the problem? thx
Problem when running rhoSonicFoam solver | gaottino | OpenFOAM Running, Solving & CFD | 3 | March 1, 2011 04:59 |
PROBLEM IN SOLVER RUNNING PARALLEL | Íñigo | CFX | 3 | February 4, 2007 05:08 |
problem running the solver | chotet | CFX | 1 | January 17, 2007 03:59 |
Gambit error when running under Linux 10.0 | Ralf Schmidt | FLUENT | 0 | July 19, 2006 09:00 |
Problem in running CFX in red hat linux | Q | CFX | 0 | March 30, 2006 09:11 |
