diesel spray and combustion with EGR
Old   May 15, 2007, 21:42
Default diesel spray and combustion with EGR
usker
Hello everybody,
I want to calculate diesel spray and combustion problem with various EGR conditions:
1. I set Unpremixed/Diffusion EBU LATCT 2. I write the reaction C12H26 + 18.5O2 -> 12CO2 + 13H2O. 3. For O2 Fixed-Fraction I specify the value depending on my EGR condition. (for example, without EGR-0.233) 4. In molecular properties for scalars I add CO2(r)and H2O(r) as active scalars. 5. In Additional scalars->Initialization, I specify Initial Mass Fractions for O2, N2, CO2(r) and H2O(r) depending on my EGR conditions. N2 always will be 0.767 right? Because if I write the reaction like C12H26+18.5(O2+3.76N2)->12CO2+13H2O+69.56N2 the N2 content is equal on the left hand side and the right hand side. But when we initialize Air for additional scalars we have to specify N2 mass fraction as 0.767, is it right? Is this procedure correct?
Please share your knowledge
Appreciate it
Old   May 16, 2007, 04:34
Default Re: diesel spray and combustion with EGR
Klaas Klever
1- 4 sounds reasonable (don't forget to define a scalar for C12H26).
Although the overall mass flow of N2 won't change (if we neglect NOx formation), the mass fraction at the inlet and the outlet will differ as you add mass with your fuel.
However, your initial conditions are only the starting point for the iterations (I assume you are running steady-state). They should not affect the solution, only the time it takes to reach that solution. The more important setting for the result is the scalar mass fractions in the boundary conditions.
hope that helps.
DIESEL COMBUSTION Benzamia FLUENT 8 January 22, 2012 00:33
diesel spray combustion equivalence ratio usker Siemens 12 March 1, 2008 06:09
Multifuel Diesel Spray and Combustion usker Siemens 12 December 1, 2007 19:08
diesel engine spray and combustion usker Siemens 6 April 24, 2006 22:36
diesel combustion Marco FLUENT 0 September 14, 2005 08:27
