Compilation error with uparm.f
Old   May 20, 2007, 21:37
Default Compilation error with uparm.f
Raghu
I am trying to run tutorial 11 from star-CD version 3.2. when i give the star command in the main terminal i am getting the below error message.
I came across others in this forum who have faced similar problem but I am not even able to figure out where the compilation error messages come out or which file are they written on to. Can someone please take a look at the below error messages and help me out with what to do.
Thanx Raghu
PNP: Initialized [2007-05-20-19:11:31] Automatic Sequential Automatic Parallel analyzer.
PNP: Allocated "lennon,1" resource (1 process).
PNP: Overload STAR master processor with external moving mesh code.
PNP: Assigned "lennon,1" to STAR solver (1 process).
PNP: Assigned "lennon,1" to external moving mesh code (1 process).
PNP: Analyzing User coding in "ufile" directory.
PNP: compiling /opt/intel/compiler70/ia64/bin/efc -w -ftz -O2 -c uparm.f -o linux64_2.4-itanium-efc_7.1-glibc_2.2.4-dso/uparm.o
PNP: ***ERROR*** Compilation error in user file "ufile/uparm.f".
PNP: ==> Please check the compilation error messages.
Old   May 30, 2007, 01:40
Default Re: Compilation error with uparm.f
george
Dear Raghu,
Have you try to run another run using a subroutine in STAR-CD? I imagine that maybe the version of FORTRAN is mistake. Check the default version of Fortran that your STAR-CD needs from installation notes. For example Absoft 9.0 i think is the required for Windows.
Regards
George
Old   May 30, 2007, 02:09
Elyor
I think in this case you should use "star -fork" in order to start solver in the terminal with moving mesh problem.
Regards,
Elyor
udf compilation error sdp FLUENT 0 February 5, 2009 02:58
UDF compilation error Hari FLUENT 0 February 22, 2008 13:40
Compilation error skabilan OpenFOAM Installation 1 September 17, 2007 13:33
Compilation error CFX 11 Beth CFX 0 July 26, 2007 19:36
Compilation error Karthick FLUENT 5 April 16, 2004 13:36
