Xvision problem
Old   June 13, 2007, 20:05
Default Xvision problem
Elyor
Hi everybody, i install star-cd v3.26 into windows xp 64bit processor, and i run the prostar, it is stopped with error message "X display error, and i checked the xvision is not responding, before xvision was working very good with 32bit processor, does anyone know how to fix this problem, thanks a lot in advance.
Regards
Old   June 14, 2007, 02:36
Default Re: Xvision problem
Airfoil
This is because your Xvision is not load at startup or was blocked by antirus software. However you can manually load your Xvision. First, open task manager and look for vservice.exe*32 under Process tab and end it process. Then go to start menu and load xvision at startup folder. You should be able to see Xvision loaded at the system tray. If you still can't get the Xvision after doing this, try to end process for Xvl.exe32 also and re-load Xvision from start menu again.
Problem in Modelling Heat Transfer Problem Deepak R FLUENT 1 December 6, 2007 09:37
Xvision Probelm Sid Siemens 2 May 17, 2006 06:44
problem in solving "wave generation" problem san FLUENT 2 April 3, 2006 23:37
star cd and xvision akin Siemens 5 October 27, 2005 21:48
Xvision - profile is already running Javidan Ahmad Siemens 2 December 4, 2003 19:29
