VARIABLES FOR SUBROUTINES
Old   October 5, 2007, 02:34
Default VARIABLES FOR SUBROUTINES
Mika Nuutinen
I'm writing a turbulent wall function for temperature and I need to get access to data that isn't listed in nom.inc's alphabetical nomenclature. Such as wall heat flux. Ther is a very long list of pointers after the nomenclature list, but I can't figure out wich of them might be the heat flux. Can anyone help? If there is a complete list of pointers and what they refer to, it would be very nice indeed
Old   October 5, 2007, 12:42
Default Re: VARIABLES FOR SUBROUTINES
Pauli
From the StarCD documentation:
"If you have an application in mind but cannot see how to code the subroutine, or cannot see the data you require, contact CD adapco or its representatives for advice."
Old   October 24, 2007, 08:06
andreas
TORHF is the variable for heat flux. But according to nom.inc it's only accessible for the bcdefw subroutine. The pointer for heat flux is hfb(heat flux boundary) I think.
by including:
POINTER (P_HFB,HFB(NWSMX,1+NSC))
COMMON /DCO19B/ P_HFB
IF(INTFLG(1).EQ.0) THEN
call cdmalloc(P_waerme,iflsiz*(pnreg))
intflg(1)=1
ENDIF
heat flux should be available by the variable hfb (W/m^2).
I think Adapco does not pass on any information on pointers and common blocks to prevent users from interfering to much with the code. Someone at Adabco's technical support told me that. But a summary of commmon blocks is handed out after adabco's user programming courses. (I didn't attend one)
Passing data/variables between subroutines Emmanuel Resch Siemens 1 August 16, 2007 12:44
subroutines in UDF kk FLUENT 3 February 9, 2007 01:38
CFX subroutines Neser CFX 0 November 8, 2005 23:07
subroutines Jared Siemens 1 August 25, 2005 13:38
fft subroutines pratap Main CFD Forum 1 August 6, 2003 16:49
