Interface in Star-CCM+
Old   March 9, 2008, 15:21
Default Interface in Star-CCM+
mk_mat
Hi guys,
I have two different regions in my computational domain, and I want to define an interface between the contact surfaces of these two regions - The perimeter of the surfaces are not equal.
How would you define the interface?!
Old   March 11, 2008, 17:07
Default Re: Interface in Star-CCM+
new2CFD
You may have to redefine the geometry so that the perimeter of the surfaces match up. You can then generate separate meshes for each. For example, if you have a cover plate over a channel; where half is in contact with fluid and half is in contact with solid, make the cover plate 2 pieces and have specify two different interfaces.
Old   March 12, 2008, 15:29
Peter Specht
You look for the boundaries of each region which have contact with each other. Then mark the two and create interface in place. (right mouse click)
Old   March 13, 2008, 08:48
NaMe
try "zip edges" tools.. if they are so close.. create feature curves then zip the properly edges..
if only i can show you interactively
good luck
how to export a mesh from star design to star cd aounallah Siemens 4 March 6, 2009 06:22
the problem of running star-cd after pro-star liu-jinsong Siemens 0 November 20, 2008 20:58
