Assembling Grids
Old   January 9, 2008, 13:52
Default Assembling Grids
benbru
The complexity of the models I've been running with Pro-Star have increased to the point where I'm getting interested in utilizing the "assemble grid" features Pro-Star/ProAM offers.
The user's guide does not seem to describe how to make a grid assembly very well and I had a few questions I was hoping the experts could answer to get me started:
1) How do you do this? Do just make save several database (.dbs) files from Pro/Surf for each component of your assembly? Should they have different DB id's? Should they all have a consistent coordinate system? (same axes AND same 0,0,0?)
2)If I am making my surface mesh in Pro/Surf do I have to do anything special to make sure the grids are going to line up correctly where two grids come into contact during the assembly step?
3)Finally to assemble the grid do I just import the first .dbs into pro-am, and then repeat the import command for the rest of my databases/components?
Thanks for your help. I have high hopes in spending less time meshing the same parts again and again
Old   January 10, 2008, 15:09
Default Re: Assembling Grids
DB
save different pieces in the same database file with different database ID or you can save it in different database files, it doesnt matter. Also you dont need to have same coordinate system or same axis.
Open prostar dbase,open,filename1.dbs dbase,get,databaseID dbase,close dbase,open,filename2.dbs dbase,add,databaseID dbase close zoom off cplot
Now you will have 2 pieces of mesh in the same prostar window. They might not be aligned correctly. Now you have to use commands "vgen" for linear translation and "vtrans" for rotation. These two commands will help you to allign the two pieces. Next you have to couple/vmerge the two meshes to create a single mesh.
Assembling a fvMatrix for a preconditioner srinath OpenFOAM Running, Solving & CFD 0 July 30, 2008 07:23
Assembling model files - help nava Siemens 0 July 31, 2007 10:09
Fixed grids --> Moving grids Maryam FLUENT 0 May 21, 2007 16:46
Accelerate the assembling of 3D convection matrix Isabel Main CFD Forum 6 December 22, 2005 12:22
DNS Grids K.Senthil Main CFD Forum 1 January 25, 2001 11:31
