how to process results
Old   February 25, 2008, 04:10
Default how to process results
pullaiah
I ran a transient case in which some chemical reactions are taking place. How can I found concentration of different species along the geometry and at different locations of geometry. Here spd file will give values only at monitoring location and that to for single cell, but I want those variables at different geometry locations and how can I get them. Please help me in this regard. Thank you.
PULLAIAH G
Old   February 27, 2008, 18:17
Default Re: how to process results
Andrea
First of all spd file give the scalar conc not in the monitoring location but in all the analized mesh...it's a global output file, in the out or run file you can see the data referred to the monitoring location.
Then for monitoring scalar conc along your mesh you really need a transiet output file .pstt, if you don't want to examine only your last time-step results. When you have it you can use the post-processing plot option in the star gui...it's a visual way to get the scalar conc along your mesh...and if you want numerical data you can choose to output that data by "printing" on the out file (or info file also I think) every X calculations...
Old   February 27, 2008, 22:31
pullaiah
Dear Andrea,
Thank you for your suggestion.you told that spd file contains global data, I am not getting your point clearly. If it contains global data, is it averaged data of all the cells or what do you mean by global data. and this spd file is giving with respect to time step.
As you told, if I use "print" option to get results, will it give numerical values of variables along the length of geometry.
Thank you.
regards PULLAIAH
Old   March 3, 2008, 19:16
Andrea
Dear PULLAIAH
yes I mean that spd file contains averaged data of all cells for a time step. Note that you can look at a particular data value in a particular cell also by the command pcross (plot the data of your interest by a contour plot, the issue the command pcross and click on the cell where you want to get the data). It's a simple command easy to use if you want to get "in time" data when you are looking at the results on scree.
I hope that helps!
Regards,
Andrea
how to convert 3d results in 2D results Ben CFX 1 February 18, 2009 16:42
the process of CFX beginer CFX 2 November 7, 2001 10:39
solidification process Li Zhiguo Phoenics 1 August 28, 2001 05:01
Fluidized bed process Istadi Main CFD Forum 0 June 21, 2001 05:43
solidification process Young Siemens 2 December 19, 1999 14:06
