Need a macro to run every timestep
Old   March 19, 2008, 18:37
Default Need a macro to run every timestep
Nate
1.) Do macros automatically run every timestep? 2.) Does anyone have a sample of such a macro?
I need to come up with my own macro to export XYZ tables each timestep but I'm not sure how to go about getting the macro to run every step.
Thanks!
Old   March 24, 2008, 16:37
Default Re: Need a macro to run every timestep
Steve
it is pretty easy to do
firstly setup your model then record a macro that contains
1) the pressing of the step button. This makes the simulation take one timestep/iteration
2) the post processing steps you want (exports etc)
Stop the recording and open up the java file. The next step is to wrap this code in a java for or while statement, for example
int imax=100; //maximum number of steps
for(i=0&#59i&#60imax&#59i++){
// insert your recorded macro code here
Any java book or a bit of work with google should sort you out.
Old   March 24, 2008, 18:13
Nate
Thanks Steve!
I guess that was kind of a no-brainer. I hadn't though about the fact that you can step just once like that.
load sheme macro (Solv Execute Command macro) manu FLUENT 2 March 13, 2008 01:00
Macro Trouble -Winows Explorer Crashes with Macro Martin Castillo FLUENT 1 July 25, 2007 04:18
timestep ousegui CFX 0 March 18, 2005 08:43
Call a macro from a macro Flav Siemens 2 July 1, 2004 05:42
timestep Eugenio Mayol CFX 2 February 8, 2001 01:39
