Star-CCM+ on UBUNTU...
Old   March 18, 2008, 18:07
Default Star-CCM+ on UBUNTU...
mk_mat
Hi guys,
I'm trying to install Star-CCM+ on UBUNTU operating system but after executing ./setup command, I am getting the following error message:
./setup: 1: Syntax error: Unterminated quoted string
Any idea?! it happens with "sudo ./setup" as well!!!
Old   March 19, 2008, 07:19
Default Re: Star-CCM+ on UBUNTU...
matej
there are few issues. Ubuntu uses dash instead of sh, unlike other distributions. You'll find more here: https://wiki.ubuntu.com/DashAsBinSh
the setup script of ccm does not follow POSIX very well. Therefore the script is not working. Unless you want to spend time finding bugs, unpack the tar.gz files yourself. it is easy, it works. In the installation help you have the directory structure, you should follow. good luck
matej
Old   March 19, 2008, 15:49
James
Or just install a decent OS like SuSe
Old   April 11, 2008, 09:30
norbinou
Install the neu version from ccm+ 3.02.006
Old   April 22, 2008, 14:30
tom
sudo dpkg-reconfigure dash
select no then
sudo dpkg-reconfigure bash
Guess u have it figured out by now though!
Instalation on ubuntu 710 basilwatson OpenFOAM Installation 17 March 16, 2012 20:16
ParaFoam on Ubuntu 804 francy OpenFOAM Installation 6 May 8, 2009 06:57
Fluent & Ubuntu 7.1 Charles FLUENT 6 April 1, 2008 00:13
Ubuntu 7.10 and Fluent Gibbon FLUENT 1 November 13, 2007 02:08
Fluent 6.3 on Ubuntu 7.04 adas FLUENT 1 March 20, 2007 19:31
