Heat exchanger forced convection modeling problem
Old   May 31, 2022, 08:40
Default Heat exchanger forced convection modeling problem
Hannes
Hannesk is on a distinguished road
Dear all,
I'm having trouble executing a cfd-model. The geometry is a simple micro-channel (1mm by 10 by 150mm) made of copper which has a certain temperature. This is cooled by water of which I know the input velocity and initial temperature at the inlet. I want to model the temperature of the fluid and the solid over the length of the microchannel. However, i have to state the temperature of the fluid at the solver. Consequently, after applying the boundary and initial conditions, the result is that the fluid is immediately the ambient temperature. Is there anyway I can model the temperatures by only having the input of fluid velocity, initial fluid temperature and wall temperature?
Edit: Forgot to mention, im using simcenter thermal/flow
With kind regards,
Hannesk
Last edited by Hannesk; May 31, 2022 at 08:43. Reason: forgot to mention something
Hannesk is offline   Reply With Quote
Visualizing Heat Transport for forced Convection in Fluids max.e Visualization & Post-Processing 0 December 10, 2021 06:30
SU2-7.0.1 on ubuntu 18.04 hyunko SU2 Installation 7 March 16, 2020 04:37
Natural Convection heat transfer problem srinivasa FLUENT 21 November 11, 2016 06:08
Solidwork flow floefd - modeling heat exchanger in a system mzreik FloEFD, FloWorks & FloTHERM 3 January 8, 2016 11:30
Forced convection Benchmark problem Raj FLUENT 0 January 28, 2009 06:10
