Dummy scalar
Old   June 4, 2008, 01:25
Default Dummy scalar
SAKTI
Hi, if I dont have the physical properties of a scalar and I want to use it as intermediate scalar in the reaction flow, is it possible to make it as a dummy scalar? I mean to empty the properties database, will it affect any calculation? cause when I check like the momentum or the reaction rate is not affected by the physical properties of the scalar, I mean without any physical properties at all. This dummy scalar will be a result of evaporation and then react with water to become other scalar. I cannot found the physical properties of the scalar anywhere.
Thanks
Old   September 4, 2008, 20:05
Default Re: Dummy scalar
hirokata
Define a scalar with "passive" influence setting. This shouldn't affect the fluid properties (e.g. density, pressure, etc.) during the calculation. You can essentially use the "dummy" scalar as a memory.
Old   September 5, 2008, 00:29
SAKTI
Hi, thanks yes its a good point
Dummy Cells/conjugate heat transfer Eric Fidelity CFD 1 November 8, 2006 13:37
Coordinate cut c-grid and dummy cells zonexo Main CFD Forum 0 December 13, 2005 05:05
scalar ? pr Main CFD Forum 2 September 1, 2003 00:26
How to deal with "dummy" cells by FVM Smith Gearheart Main CFD Forum 7 November 15, 2002 00:35
scalar equation Arturo Ortiz FLUENT 3 October 8, 2000 12:36
