autosave output of x-y plot for unsteady case
Old   August 7, 2008, 17:54
Default autosave output of x-y plot for unsteady case
Eric
I'm using Star-CCM+ 3.04 and have run into an unfortunate limitation when postprocessing unsteady cases. I've been using XY plots to display velocities along a lineprobe, then exporting for visualization with other datasets. With my unsteady cases, I have it autosaving every 0.1 seconds for a max physical time of 1 second. I want a set of x-y data for every autosave position, IE 0.1s, 0.2s, etc.
I can get a "scene" to do this wonderfully with the attributes, update tab. A plot, however, does not have this functionality. It looks like reports only do averaged data, not say Y-velocities along a line but only its average value, otherwise I could go the report/monitor route.
If I wanted, I could go in manually to each of the ten .sim files associated with each autosave time and export a plot's data, but that's... not right. I mean it will work but is sort of an error prone to do whatwith clicking and naming 100+ times... I've got six+ plots, 10 autosaves, and will be running more than one case...
Any ideas?
Old   August 8, 2008, 20:48
Default Re: autosave output of x-y plot for unsteady case
a
You need to record a macro. Just click the record button and go through saving your plots, then click stop. You can then read in this file on each of your sim files. I dont know the exact command but you can specify a macro to run from the command line so you wont have to open them all up individually.
Ideally, you would write the macro to save the plots as the simulation is running, but that might require a little java programming.
Old   August 8, 2008, 20:50
a
Also, I think you are correct about the reports only saving averaged data. What I had to do was monitor data at a bunch of points instead of a line.
Old   August 10, 2008, 03:35
Eric
This is great. Now I have some hope at least
Will have to figure out how to trip the macro by timestep, hopefully it's possible.
Macro to output a plot curve E Fardream Fidelity CFD 5 July 9, 2007 08:13
output data for unsteady flow case wieke Main CFD Forum 0 September 30, 2003 04:40
SOS autosave unsteady particle tracking Alex Munoz FLUENT 2 June 27, 2003 00:37
plot for unsteady case george FLUENT 5 May 16, 2003 15:45
Unsteady output keith CFX 1 July 12, 2001 07:29
