June 15, 2008, 11:20 |
automatic *.inp file execution
Hello!
Is there any possibility to execute *.inp file automatically when prostar.exe starts? I would like to prostar.exe automatically starts with certain *.inp file and does all included in this file commands. Something like that: c:\...\bin\prostar.exe -b -some_key file.inp ??? Thanks and regards, Ivan |
June 15, 2008, 16:39 |
Re: automatic *.inp file execution
Using Linux you can pipe it using "<"
prostar -b < file.inp Do not know if this works for Windows but I do not think so. Otherwise you could try something like ifile file.inp in your proinit. Regards |
June 16, 2008, 01:28 |
It works for Windows, thanks!
June 16, 2008, 11:43 |
Put a line containing "ifile file.inp" in your PROINIT file. Or you can just put the commands directly in PROINIT.
On Unix/Linux, the PROINIT file goes in ~/star.dir. If present, it is automatically run each time you start a PROSTAR session. I believe you can also place PROINIT in the current working directory. |
Execution Terminated: STP file found | Rita | CFX | 2 | January 8, 2007 23:12 |
Automatic saving of file after getting solution | venugopal | FLUENT | 5 | June 17, 2004 09:45 |
Execution problem | Jiri | Siemens | 3 | October 16, 2003 09:46 |
automatic case file loading in fluent | calogero | FLUENT | 8 | May 15, 2003 02:48 |
romote execution | Yong | FLUENT | 0 | January 17, 2003 04:26 |
