ProEngineer Wildfire to Star-CCM+
Old   June 14, 2008, 16:56
Default ProEngineer Wildfire to Star-CCM+
McGrath
I am having a heck of a time exporting geometry from ProE to Star-CCM+ without encountering non-manifold surfaces. The only formats I can get to work are IGES and STEP. I've tried setting the accuracy in ProE to 1.e-06 but I still get surface problems. Do any ProE users have any advice to give?
Old   June 15, 2008, 04:38
Default Re: ProEngineer Wildfire to Star-CCM+
mk_mat
Have you tried Parasolid format (file.x_t)?!
Old   June 15, 2008, 16:27
McGrath
It won't even import the parasolid. It just throws up an error almost immediately. Any more suggestions? ~Thanks
Old   June 15, 2008, 16:41
BastiL
Is import to ccm+ essential? It does not really have a geometry core so far. SO it has to facet gerometry.
Old   June 15, 2008, 19:00
McGrath
How can I use Star-CCM+ if I can not import geometry?
Old   June 16, 2008, 04:27
mk_mat
I would recommend update your ccm+ version to 3.02.006 if you haven't done it yet!
I've imported parasolid files many times and it works perfectly fine.
This is what I do in Pro/E:
File > Save a Copy > then filename.x_t > ok
select "Solids" & "Shells" > ok
Old   June 27, 2008, 02:27
Emir_GALATASARAY
i recommend you not to use Pro-E for transformation. Pro-E exports geometries very badly.
PRO/E Wildfire Integration Matt FLUENT 1 April 10, 2007 01:56
ICEMCFD - Proe wildfire 3 direct cad interface? Phil CFX 1 February 27, 2007 20:31
direct import proEngineer nasser FLUENT 4 June 25, 2006 14:53
ProEngineer Access Donna CFX 3 July 11, 2003 09:36
