Two gas Mixing
Old   July 14, 2008, 08:14
Default Two gas Mixing
Brian
Hopefully someone can give me some help on what is happening:
I'm modeling gas mixing in 2-D in Star-CCM+. I have a heavy cold fluid in a volume (area) above a lighter hot fluid, they are connected by a small opening. I'm doing a time-dependent calculation to see how the fluid mixes due to the buoyancy difference. I'm using ideal gas, and my gravity is on.
When I run it the concentration contours looks as you'd expect (with good mixing). But the temperatures are strange. At later time steps I get some cells (just a few) with a temperautre much higher than the initial hot temp, and I get some temps lower than the initial low temp.
If I lower my time step, or lower under-relax for energy, or run more inner iterations/ time step it does better. But there are still a few cells with high temperatures.
But to me it seems like this should be a relatively easy problem, so I'm wondering if there are tips for how to model this. I'm using implicit time solving, segregated solvers and laminar viscous modeling.
Also: I have the same problem in Fluent.
Any help would be grealy appreciated! Thank you much
egr mixing subhash FLUENT 1 November 4, 2009 06:18
two gas mixing Brian FLUENT 0 July 11, 2008 12:20
Mixing Toni Vainio Siemens 2 January 19, 2005 07:31
ideal gas mixing law and mass-weighted mixing law Shankar FLUENT 0 June 24, 2003 13:25
Mixing prasat Main CFD Forum 0 May 26, 2003 04:32
