lagrangian multiphase analysis
Old   September 19, 2008, 06:34
Default lagrangian multiphase analysis
Marco
Hi !
I am using Star-CCM+ and I am doing lagrangian multiphase analysis for tracking grease droplet particles.
I am simulating a simple pipe with 1 inlet and 1 outlet, and the other boundaries are set to "rebound" condition, so all the particles will escape throw the outlet.
I want to calculate the quantity of particles leaving the domain, and I aspect that is the same that I inject, but it is not !!! I do a sum report of Incident mass flux on Outlet, and I multiply it for the outlet area to obtain the mass flow rate. The value that I obtain is 100 times higher than inlet value, how it is possible ? There is any other way to calculate the particle mass that leaves the domain ?
thanks in advance to everybody ...
Marco
Old   September 19, 2008, 08:28
Default Re: lagrangian multiphase analysis
Richard
Incident mass flux is mass/area/time, so you should do a surface integral report of it to get mass/time. This is not the same as (area)*(sum report) unless all the faces have the same area.
Also make sure you are injecting what you think you are, e.g. is the mass flow rate specified per injection point or total.
Old   September 20, 2008, 11:41
lelia
Hi, you can find anything about your particles (almost ) if you select them all and import their characteristics into a output folder. after u select the particles and plot them on the screen the commands are: ofile,part.out dlist,dset dlist,dset,,,other ofile,screen close,part.out
hope it helps! regards, lelia
Old   September 22, 2008, 09:43
Marco
Thank you Richard, now it works with your advise. I don't know why I used the sum function ....
Cheers
Marco
lagrangian multiphase analysis bala Siemens 3 April 28, 2008 02:13
lagrangian multiphase analysis bala Siemens 2 April 24, 2008 07:52
lagrangian multiphase analysis bala Siemens 0 April 15, 2008 01:35
analysis restart for lagrangian multiphase mic Siemens 0 July 5, 2007 08:36
Lagrangian multiphase switch Alfred Herman Siemens 1 October 14, 2003 07:28
