September 14, 2008, 21:59 |
Multicomponent with Temperature dependent
Dear All,
I want to simulate the real exhaust gas component, the case is temperature dependent. Which thermophysical properties should I use? The multicomponent option doest concern the temperature dependent right? how about the polynomial option? will it concern the multicomponent effect? Best regards Sakti |
September 14, 2008, 23:48 |
Re: Multicomponent with Temperature dependent
Multicomponent means concentration dependent, this option is suitable for multi-component mixtures. Depending on the density setting, STAR uses a constant specific heat Cv or Cp (or any other thermophysical property) for the background fluid. It also uses constant specific heats for any additional scalars present to calculate a mixture specific heat weighted according to the local concentration of each component.
Polynomial calculates the specific heat Cp (or any other thermophysical property) as a polynomial function of temperature (non-linear change of specific heat with temperature). If you click Define/Edit polynomial, it opens a special Polynomial Function Definition dialog in which polynomial coefficients may be created or edited, as necessary. Regards |
September 15, 2008, 01:20 |
Dear Mr. Usker
Thank you for your reply, what if the properties value both concentration and temperature dependent? regards Byan |
September 15, 2008, 22:09 |
Then your Density will be a function of pressure and temperature.
Molecular Viscosity - MultiComponent, (if your Viscosity is temperature dependent, then you have to use Sutherland. Please, refer to Star-CD Methodology. Specific Heat - Polynomial Conductivity - Constant or Polynomial (usually Constant, but it depends on the flow conditions) |
Temperature Dependent Loads | RP | FloEFD, FloWorks & FloTHERM | 3 | March 22, 2012 01:46 |
question about a temperature dependent HTC | Christoph Ley | Phoenics | 2 | June 5, 2008 09:05 |
Time Dependent Temperature Dependent BC Analysis | RP | Main CFD Forum | 1 | March 28, 2008 01:22 |
Temperature dependent property | kdarc | OpenFOAM Running, Solving & CFD | 3 | March 27, 2007 16:21 |
to take K & Cp as temperature dependent | kishore rathore | FLUENT | 1 | February 17, 2004 04:33 |
