STAR-CCM+ , Re-Running same simulation
Old   September 25, 2008, 06:35
Default STAR-CCM+ , Re-Running same simulation
MAB
Hi, I have finished running a simulation , now i want to re-run the same simulation with some changes . Please give me some hint how to do that in STAR-CCM+
Old   September 25, 2008, 06:39
Default Re: STAR-CCM+ , Re-Running same simulation
Name
from mail menu select Solution >> Clear Solution then do your changes.. then Solution >> Run (Ctrl+R)
Old   September 25, 2008, 06:57
MAB
Thanks !!!
Old   September 25, 2008, 17:34
anon
I'd recommend NOT clearing your solution. Just make the changes and hit run. That way, your initial solution will be your old solution, and the simulation will converge faster.
Old   September 29, 2008, 04:17
Andrea
You can also "reset for restart". By this way the code keeps the last iteration of the previous computation and use it as "initial field" for the new simulation...but the iteration counter is reset and externally it looks like a completly new sim, but it conrverges faster than the original one.
Star-CCM+ running in openSUSE Thiago Siemens 6 January 20, 2009 09:23
the problem of running star-cd after pro-star liu-jinsong Siemens 0 November 20, 2008 20:58
script for running star Celia Siemens 8 December 2, 2004 22:46
star is not running the simulation in windows Arnab Siemens 1 August 2, 2004 02:40
