January 23, 2009, 01:27 |
Unable to Capture Shock in Transonic Flow
I'm modeling transonic flow across a turbine blade.The conditions are blade inlet angle=58.9deg, Mach=0.845, turbulence model is k-w. I am able to observe Mach numbers of greater than 1 across my blade..However, I am not able to see a shock across the blade? Any inputs? Thanks |
January 23, 2009, 14:51 |
Re: Unable to Capture Shock in Transonic Flow
do you use ideal gas?
January 23, 2009, 20:05 |
Re: Unable to Capture Shock in Transonic Flow-----
Yes, I am using Ideal Gas...should i use constant density gas instead??
January 26, 2009, 07:01 |
Hi there,
I used constant density gas...It gives me an improved model of the Cp distribution of the blade...However, it is unable to track the shock.. Timothy |
January 26, 2009, 18:58 |
You shouldn't be using constant density for transonic flow. If you say you can see M>1, then somewhere you should also have M<1, that's where your shockwave is. Try making the mesh denser to capture the shock.
January 27, 2009, 23:37 |
Hi anon,
Thanks for your reply, tried refining the mesh til the absolute size of the volumetric control is 0.03mm but i still could not detect the shock or drop in Mach in my model. The chord length is around 60mm fyi...Tried inviscid flow but it still shows the same pressure distribution...Any suggestions ?? Novice in this area. Tim |
January 29, 2009, 06:05 |
Hi just to give the full picture...Here are the parameters of my model:
3D, Stationary, Ideal Gas, Coupled FLow, COupled energy, steady,turbulent, RANS, K-E model, turbulence intensity 0.1, turbulence viscosity ratio 500, velocity [272.1,442,0] m/s, temp 987.2K, pressure (gauge) 147675Pa. Using stag inlet for inflow, pressure outlet for outflow, and wall(periodic boundary) for upper and lower part of the model. Thanks Tim |
TRANSONIC FLOW in RHOSIMPLEFOAM | dinonettis | OpenFOAM Running, Solving & CFD | 10 | September 13, 2018 10:22 |
Unable to get turbulent flow using LES model | Tang Jingwei | FLUENT | 6 | March 21, 2009 17:59 |
fluent6 unable for transsonic, compressible flow ? | Tobias | FLUENT | 4 | October 17, 2005 12:09 |
TRANSONIC FLOW? | manish mehta | Main CFD Forum | 1 | March 24, 2005 14:03 |
Unsteady flow to capture acoustics (press. fluct) | Ana Garcia | FLUENT | 0 | June 24, 2003 11:27 |
