fuel injection
Old   February 5, 2009, 05:25
Default fuel injection
Johannes P.
Hey!!
I wanna simulate an injection of fuel(Dodecane(L)) into a high pressure cell. I wanna have a look to the length of the injected fuel jet and to the diameter and velocity of the fuel droplets.
It's an Lagrangian Multi-Phase spray injection with atomization.The Atomization model is the "Huh-Model", the "MPI-2" is the nozzle model. Heat, Mass and Momentum Transfer are Standard with 0 for mass coef. and 1 for the slip factor.
there is one inlet and one pressure boundary created. I wanna simulate pressures between 1e+05 and 100e+05Pa. That I can see how the pressure influences the length of my jet and the velocity and diameter of my parcels
So, the problem is that the length of the jet is still constant. Doesn't matter if the pressure in the cell is initialized to 1e+5Pa or to 500e+5Pa. So, what's wrong with my simulation?
I'm running the code of version 3.26.
Maybe you've an idea;-) Thanks a lot.
Johannes
P.S. I'm a student from Germany, so sorry for my bad english ;-)
Old   February 5, 2009, 06:42
Default Re: fuel injection
Kian Mehravaran
Hi Johannes,
Are you using RANS or LES? Also, when you say length of your jet, do you mean the liquid jet, or the gas jet?
Kian Mehravaran
Old   February 5, 2009, 07:08
Johannes P.
HEY Kian, i mean the length of the liquid jet (the length of the fuel jet). What's RANS or LES?
Thank you very much.
Johannes
Old   February 5, 2009, 07:26
Andrea
RANS = Reynolds Averaged Navier Stokes equations, LES = Large Eddy Simulation, they are two ways of modeling turbulence...two radically different approach.
Try to look at the cfd wiki for more info
For the injection problem, do you get the correct pressure (the pressure you want) in the injection chamber? Have you verified that?
Regards
Old   February 5, 2009, 08:14
Johannes P.
hey!
ok, than i use RANS!
I get definitely the right pressure in the chamber.
try tp find sth. in the WIKI.
thanks, Johannes
Old   February 5, 2009, 09:07
Kian Mehravaran
Now the next question is how do you calculate the length of the liquid jet? By looking at the volume fraction? or do you look at the droplets directly? What is the temperature in the chamber? It could be that evaporation is very dominant in your case.
Kian Mehravaran
Old   February 19, 2009, 08:45
Daniel
Hello Johannes,
Although I am not familiar with star, my first guess is that you are doing an incompressible simualtion. In that case, the results do not depend on the actual level of the pressure, but just on the pressure gradient. If so, both initializations should lead to the same results.
regards
Fuel Injection Problems..... Maria Siemens 1 August 25, 2007 09:02
Fuel injection Rams FLUENT 12 June 20, 2006 01:25
Fuel Injection for Racing Car Derry CFX 1 January 30, 2006 21:38
injection of fuel into tank filled with fuel mujahid FLUENT 1 February 19, 2004 06:36
Fuel injection Enrico Siemens 2 December 23, 1999 03:37
