Load pst files on v4
Old   February 11, 2009, 11:32
Default Load pst files on v4
jimmer
Hello. I need to load results from v3.26 to v4. The first version's file extensions are pst and pstt for steady state and transients calculations. How can I load these files on STAR_CD v4.
Old   February 11, 2009, 14:13
Default Re: Load pst files on v4
donald
There is no situation where you would have to do this. If you have results in v3.26: post-process in v3.26
You would only upgrade to star v4 if there are new physics and models needed that were not v3.26, in this case you would run in v4.
Old   February 11, 2009, 16:40
Balduin Bankerotti
Nonsense.
You can use v4 perfectly well for postprocessing old results, maybe with some small limitations when there are couples.
Just use "load file.pst" to load a steady post file or "trload, file.pstt" or loading a transient post file.
The only problem is, that you can not load several pstt-files at once in v4. There is a small prostar bug.
I just used v408 prostar for postprocessing an v326 es-ice run and it works, even with events and moving mesh and spray and ...
Old   March 11, 2009, 03:32
jimmer
Thank you B.B. That was really helpful.
try to load a edited UDF austin Main CFD Forum 0 February 20, 2009 05:25
load a file.msh giovanni Main CFD Forum 2 September 3, 2008 07:48
Converting ANSYS CFX files to Fluent files Martin S. Rasmussen FLUENT 3 January 30, 2007 15:08
Is possile to load transient files automatically ? veera CFX 6 January 2, 2006 01:40
i installed C++ BUT I CAN;T LOAD stk FLUENT 1 February 16, 2004 21:19
